DeanoCoupe Posted September 24, 2018 Report Share Posted September 24, 2018 Ok before I go steaming ahead with this I presume removing and refitting the rear (o/s) indicator lamp unit is straight forward.... 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 24, 2018 Administrators Report Share Posted September 24, 2018 Yes, very straightforward just remember to remove the nearest plastic trim clip from the centre rear plastic trim as the boot carpet trim is held in that area also a long 8mm socket is a must though as the nuts are on long threads although loosen and spin-off with your fingers, can't find a video online so something to add to my video list unless you wanted to to do one that is... Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 28, 2018 Administrators Report Share Posted September 28, 2018 This topic linked below should help (now I've updated the pictures) if you haven't already done the job? Link to comment Share on other sites More sharing options...
