Founding Member AhsyV6 Posted April 4, 2016 Founding Member Report Share Posted April 4, 2016 Just wanted to share the installation of my new rear EBC Grooved and Dimpled discs and Redstuff pads. My intention was for this to be done during my visit to Honda 6 HQ but I was sent the wrong rear discs so I did the fronts only. Luckily for me Stu and Rich loosened the rear disc screws and greased them for me for easily removal......THANK YOU! Stu also sent me replacement screws for Volkswagen cars with an Allen key head which he prefers over the Honda ones. I greased these when installing the discs. You will also see that I painted the calipers in brushable Black Hammerite Smooth paint albeit VERY badly.....I'm actually quite pissed at my effort and shouldve spent longer in prep(which is the standard approach in ANYTHING we do). It got dark and I got soaked and just wanted the job to be over. I even left my Coupe on my friends drive 20 miles away so the Hammerite can cure (Stus advice) and will pick it up on Wednesday before going to badminton. I have decided I will spray the fronts but haven't decided if I should use smooth or Hammer finish so that the imperfections blend in to the textured finish. The odd thing is that out of the 4 pads only one had the wear indicator attached where the originals had one on each side. Anyway you will see that I incorrectly fitted 2 pads with the Caliper openings on the back of the pad to one side. I corrected this afterwards 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 5, 2016 Administrators Report Share Posted April 5, 2016 Top job that man, they look the business and at least the groove is the right way round on the rear discs 1 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted April 5, 2016 Author Founding Member Report Share Posted April 5, 2016 6 hours ago, hughezee said: Top job that man, they look the business and at least the groove is the right way round on the rear discs Thanks mate.....I did think about just matching the direction with the fronts but then thought I'll swap them over when I paint the front calipers. 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted April 5, 2016 Founding Member Report Share Posted April 5, 2016 Great post Ahsy, lots of pics just how we like it. 1 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted April 10, 2016 Founding Member Report Share Posted April 10, 2016 Good stuff Ashy I must paint mine a some point. I will be using smooth silver on mine.BTW the disks look good as well 1 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted April 10, 2016 Author Founding Member Report Share Posted April 10, 2016 1 hour ago, Brett said: Good stuff Ashy I must paint mine a some point. I will be using smooth silver on mine.BTW the disks look good as well Thanks mate.....obviously your paint job will be better that mine! Use a good wire brush as it does wonders and then an assortment of sandpaper(which I had bought especially but clearly didn't use!!!!). I cleaned them down with caliper cleaner which does en excellent job, I bought isopropyl alcohol for cleaning but it looked like the caliper cleaner did the same job and it evaporated very quickly too. On Stus advice I didn't do the fronts at his place as he said the Hammermite needs to cure bout 48hrs. If not then the oil in the paint when heated under braking could cause the paint to blister. Good luck and look forward to the pics! 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 13, 2016 Administrators Report Share Posted June 13, 2016 On 10/04/2016 at 10:39 AM, Brett said: Good stuff Ashy I must paint mine a some point. I will be using smooth silver on mine.BTW the disks look good as well Follow up shot on Brett's painted calipers 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 13, 2016 Administrators Report Share Posted June 13, 2016 Also how are the EBC Grooved and Dimpled discs going Ahsy, as I am more steered towards OEM’s or Equivalents these days in light of my experiences with upgraded brakes allot are just for show or just poor quality by comparison Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted June 13, 2016 Author Founding Member Report Share Posted June 13, 2016 4 hours ago, hughezee said: Follow up shot on Brett's painted calipers Very nice and looks like a solid block of clean metal now. still haven't done mine yet......the list just gets longer! The Lambda arrived today and that's been added to the list too! Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted June 13, 2016 Author Founding Member Report Share Posted June 13, 2016 4 hours ago, hughezee said: Also how are the EBC Grooved and Dimpled discs going Ahsy, as I am more steered towards OEM’s or Equivalents these days in light of my experiences with upgraded brakes allot are just for show or just poor quality by comparison These are my second pair as I had Black Diamond discs before but they were drilled and grooved. I really like them and of course I like the look too. I think you'd have to drive the coupe to see how different they feel to OEMs. In the past on my Legend coupe and previous Accord coupe I had OEMs warp on me from overheating during excessive braking so that's another reason I went for decent aftermarket discs. You mentioned that I may need one more brake fluid change and feel that I do as there is a little bit more play/feels a little spongy. I had mintex pads before and now have the EBC Redstuff and I'm pretty impressed with the bite and more so of the massive reduction in brake dust. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 13, 2016 Administrators Report Share Posted June 13, 2016 Good Stuff, yeah a couple of fluid changes will help allot as your pedal felt softer than I'm used to before I bled the system, so there's plenty of room for improvement The only reason why I asked about the brakes is a drilled disc is more of a nice look than an advantage these days, they are more prone to warping or cracking due the drilling weakening them, hence why they are not used in racing. So your pad choice is critical factor and how much you stamp on them will determine how long they last Nevertheless they look the part my oversized vented discs are thinker than Brett's so warping isn't my concern, so keep us posted on your progress with them buddy... Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted June 13, 2016 Author Founding Member Report Share Posted June 13, 2016 Because of the warping on my OEMs that's why I decided to try them and have really liked them. I think I mentioned before if money wasn't an object I would install the big brake upgrade by Brembo but I won't be at £1200 just for the fronts! I will keep you up to date mate and actually may book a date with you in July for a few bits. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 13, 2016 Administrators Report Share Posted June 13, 2016 They look the business, but you know me I want my cake an eat it and it would be more than a pleasure to see you an your glorious green gleam machine buddy 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 27, 2016 Administrators Report Share Posted June 27, 2016 Just replaced the brake pads and hoses on the coupe and I couldn't resist painting them either 2 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted June 28, 2016 Author Founding Member Report Share Posted June 28, 2016 Hammerite smooth or hammered finish? Brushed or sprayed? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 29, 2016 Administrators Report Share Posted June 29, 2016 On 28/06/2016 at 8:16 AM, AhsyV6 said: Hammerite smooth or hammered finish? Brushed or sprayed? Smooth and lazy spray, but I did remove them completely 2 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted June 30, 2016 Founding Member Report Share Posted June 30, 2016 Nice. A subtle red 'Honda' decal would set them off nicely. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 30, 2016 Administrators Report Share Posted June 30, 2016 Good idea Geoff bring a fine brush when your next over, you can have ago for me 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted June 30, 2016 Founding Member Report Share Posted June 30, 2016 I'll have a look on fleabay....there might be small Honda logo stencil that you can spray with red paint as I suspect stickers or vinyl decals will be no good on calipers due to the heat, wet etc. 2 Link to comment Share on other sites More sharing options...
KingK0ng Posted April 19, 2019 Report Share Posted April 19, 2019 I'll soon replace all my brake discs and pads for the CG4 and was thinking of EBC premium plain discs front and rear. One of the reason is that they have that black anti-rust coating and i think it's an nice addition. Also i'm looking for some brake pads that produce the less dust possible. So what are your though on the EBC premium discs, any experience ? Also what brake pads do you recommend for less dust possible ? Since recommendation for brake pads may vary on style and driving condition, i can say that i'm not a spirited driver but more a cruiser and i don't drive in urban city a lot so not that much stop and go. My coupe is more a week-end pleasure. Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted April 19, 2019 Author Founding Member Report Share Posted April 19, 2019 Not familiar with the EBC premium but I have the grooved and dimpled which I really like. I have black diamond grooved and vented and think I might go back to these. Is definitely recommend the EBC Redstuff.....excellent stopping power with minimal brake dust....massive difference 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted April 20, 2019 Report Share Posted April 20, 2019 Here in Belgium if not from factory drilled/grooved discs are no tolerated by the car control inspection. I must keep the plain discs in front.. if you're satisfied with the EBC, why you want switching back to the black diamond ? 2 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted April 20, 2019 Author Founding Member Report Share Posted April 20, 2019 For looks mainly as the coating in the centre didn’t rust and they were drilled and EBC don’t make these. 1 Link to comment Share on other sites More sharing options...
