Administrators hughezee Posted September 1, 2015 Administrators Report Share Posted September 1, 2015 Front Shock Absorber illustrated with Honda UK Part Numbers.1 51401S87A02 SPRING, FR. (SHOWA) £110.89 2 51601S80A17 ABSORBER ASSY., R. FR. SHOCK (###) £305.21 3 51602S80A17 ABSORBER ASSY., L. FR. SHOCK £305.22 4 51605S80A05 ABSORBER UNIT, R. FR. SHOCK £180.47 5 51621S84A01 WASHER, SHOCK ABSORBER MOUNTING £3.30 6 51631SV7004 RUBBER, SHOCK ABSORBER MOUNTING (SHOWA) £12.50 7 51675S84A01 BASE, FR. SHOCK ABSORBER MOUNTING (SHOWA) £57.12 8 51685SR0004 PLATE, DUST COVER (A.S.I. SHOWA) £3.46 8 51685SH3014 PLATE, DUST COVER (SHOWA) £4.91 9 51686S84A01 RUBBER, FR. SPRING MOUNTING £23.23 10 51689SH3004 PLATE, BUMP STOP (SHOWA) £5.95 11 51689SP0004 COVER, DUST (SHOWA) £9.37 12 51722S84A01 RUBBER, FR. BUMP STOPPER (A.S.I. SHOWA) £20.35 13 51728SB0004 COLLAR, SHOCK ABSORBER MOUNTING (SHOWA) £5.35 13 51728SR0003 COLLAR, SHOCK ABSORBER MOUNTING (DUFFY STEEL PARTS) £1.58 14 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM) £3.91 15 90364SG0004 NUT, SELF-LOCK, 10MM (SHOWA) £3.60 16 51606S80A03 ABSORBER UNIT, L. FR. SHOCK £180.47 Front Suspension (incl. ABS) Upper Arm & Knuckle illustrated with Honda UK Part Numbers.1 51210S84A02 KNUCKLE COMP., R. FR. £372.492 51215S84A02 KNUCKLE COMP., L. FR. £372.49 3 51225S84A01 BOOT, LOWER BALL DUST £10.84 4 51450S84A01 ARM COMP., R. FR. UPPER £275.765 51460S84A01 ARM COMP., L. FR. UPPER £275.766 51464S04013 BOOT, UPPER BALL JOINT £20.12 7 52226SL0003 CIRCLIP, LOWER BALL (MUSASHI) £7.26 8 52338SL0003 CIRCLIP, CONTROL ARM £4.56 9 57450S84A52 SENSOR ASSY., R. FR. £208.49 11 57451S82G01 BRACKET, SECURITY HORN £6.98 12 57451S84A50 BRACKET, L. COUPLER £5.15 14 57455S84A52 SENSOR ASSY., L. FR. £208.49 15 90172S04003 BOLT, FLANGE, 10X68 £3.80 16 90321SE0000 NUT, UPPER BALL PIN, 10MM £4.18 17 90363SZ3003 NUT, UPPER ARM, 12MM £5.40 18 91540SV4003 CLIP, HARNESS BAND (NATURAL) (145.2MM) £3.77 19 934020601208 BOLT-WASHER, 6X12 £0.86 20 9407006080 NUT-WASHER, 6MM £0.86 21 9420120180 PIN, SPLIT, 2.0X18 £0.59 22 9420130220 PIN, SPLIT, 3.0X22 £0.71 24 957010601208 BOLT, FLANGE, 6X12 £0.86 25 957010601608 BOLT, FLANGE, 6X16 £0.86 Front Suspension Lower Arm & Stabilizer illustrated with Honda UK Part Numbers.1 51300S87A01 SPRING, FR. STABILIZER £148.38 2 51306S87A01 BUSH, STABILIZER HOLDER £9.79 3 51308SW3000 BRACKET, FR. STABILIZER £10.32 4 51320S84A01 LINK COMP., R. FR. STABILIZER £56.21 5 51321S84A01 LINK COMP., L. FR. STABILIZER £56.21 6 51362S84A01 ROD, FR. RADIUS £97.38 7 51355S84A00 ARM COMP., R. FR. LOWER £274.85 8 51362S87A02 ROD, L. FR. RADIUS £67.72 9 51365S84A00 ARM COMP., L. FR. LOWER £190.16 10 51381S84A01 BUSH, FR. RADIUS ROD (RR.) £13.61 11 51391S84A01 BUSH, RADIUS ROD (FR.) £13.61 12 51393SV1A01 BUSH, FR. LOWER ARM £27.59 13 51394S84000 WASHER, CASTER ADJUSTER £3.16 14 51398SM4000 COLLAR, RADIUS ROD £7.91 15 51399S0A000 WASHER, FR. RADIUS ROD £5.96 16 51810SV4004 BUSH, SHOCK ABSORBER FORK (YAMASHITA) £30.19 16 51810SV4003 BUSH, SHOCK ABSORBER FORK (HOKUSHIN) £30.19 17 51811S84A00 FORK, R. FR. SHOCK ABSORBER £115.48 18 51821S84A00 FORK, L. FR. SHOCK ABSORBER £123.20 19 74180S84E00 BAR COMP., R. FR. STRUT £75.94 20 74185S87E00 BAR COMP., L. FR. STRUT £55.73 21 90002S10000 NUT, FLANGE, 10MM £0.17 22 90117SM4003 BOLT, FR. SHOCK ABSORBER LOCK (10X44) £4.22 23 90118SL4003 BOLT, SELF-LOCK, 12X84 £8.14 24 90121SM4010 BOLT, SHOCK ABSORBER FORK (12X98) £5.51 25 90178S84A00 BOLT, FR. RADIUS ROD (14X37) £5.83 26 90215SB0003 NUT, SELF-LOCK, 12MM (SATO RASHI) £3.56 27 90303SF1003 NUT, SELF-LOCK, 12MM £4.20 28 90306SB2013 NUT, SELF-LOCK, 10MM £0.17 29 9407108080 NUT-WASHER, 8MM £0.86 30 958011001808 BOLT, FLANGE, 10X18 £0.48 (€0.55) ($0.80) 004 Rear Shock Absorber illustrated with Honda UK Part Numbers.1 51621S84A01 WASHER, SHOCK ABSORBER MOUNTING £3.30 2 51685SH3014 PLATE, DUST COVER (SHOWA) £4.91 2 51685SR0004 PLATE, DUST COVER (A.S.I. SHOWA) £3.46 3 51728SB0004 COLLAR, SHOCK ABSORBER MOUNTING (SHOWA) £5.35 3 51728SR0003 COLLAR, SHOCK ABSORBER MOUNTING (DUFFY STEEL PARTS) £1.58 4 52441S84A22 SPRING, RR. (A.S.I. SHOWA) £96.07 5 52610S80A12 ABSORBER ASSY., RR. SHOCK (###) £267.67 6 52611S80A02 ABSORBER UNIT, RR. SHOCK £158.12 7 52620S80A12 ABSORBER ASSY., L. RR. SHOCK (###) £254.93 8 52622S84A01 BUSH, RR. SHOCK ABSORBER LOWER £20.86 9 52631S84A01 RUBBER, RR. SHOCK ABSORBER MOUNTING (SHOWA) £12.73 10 52675S84A01 BASE, RR. SHOCK ABSORBER MOUNTING (A.S.I. SHOWA) £66.95 11 52686S84A01 RUBBER, RR. SPRING MOUNTING £25.52 12 52688S84A02 SLEEVE, RR. DUST COVER £37.39 13 52690SG0000 PLATE, BUMP STOP £6.64 14 52722SV1A02 RUBBER, RR. BUMP STOPPER (SHOWA) £23.45 14 52722SM4013 RUBBER, BUMPER STOPPER (POLYURETHAN KASEI) £23.45 15 52748S84A02 COVER, RR. LOWER MOUNT DUST £15.32 16 90182S84A00 BOLT, RR. DAMPER, (10X81) £5.83 17 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM) £3.91 18 90364SG0004 NUT, SELF-LOCK, 10MM (SHOWA) £3.60 19 52689SG0014 END, DUST COVER £11.41 Rear Suspension Lower Arm & Stabilizer illustrated with Honda UK Part Numbers.1 52210S84A52 KNUCKLE COMP., R. RR. £552.18 2 52215S84A52 KNUCKLE COMP., L. RR. £350.46 3 52300S82A01 SPRING, RR. STABILIZER £156.01 4 52306S82A01 BUSH, RR. STABILIZER HOLDER £23.12 5 52308SZ5000 HOLDER, STABILIZER BUSH £9.89 6 52320S84A01 LINK COMP., R. RR. STABILIZER £54.61 7 52325S84A01 LINK COMP., L. RR. STABILIZER £54.61 8 52338SL0003 CIRCLIP, CONTROL ARM £4.56 9 52340S84A01 BRACKET, R. RR. LINK STABILIZER £15.95 10 52345S84A01 BRACKET, L. RR. LINK STABILIZER £15.95 11 52350S84A01 ARM COMP., RR. LOWER £81.80 12 52360S84A01 ARM COMP., RR. CONTROL £92.60 13 52364634020 WASHER, LOWER ARM £2.82 14 52365SM4004 BUSH A, RR. LOWER ARM (YAMASHITA) £14.78 15 52370S84A51 ARM COMP., R. RR. TRAILING (DISK) £46.42 16 52375S84A51 ARM COMP., L. RR. TRAILING (DISK) £143.24 17 52380S84A01 ARM COMP., RR. LEADING £49.67 18 52387S84A00 BOLT, CONTROL ADJUSTING £11.57 19 52388S84A00 PLATE, CAM £4.4920 52390S84A01 ARM COMP., RR. UPPER £211.33 21 52454S84A01 BOOT, UPPER DUST £14.84 22 57452S84A50 BRACKET, RR. COUPLER £3.46 23 57470S0KA53 SENSOR ASSY., R. RR. £220.10 24 57475S0KA53 SENSOR ASSY., L. RR. £220.14 25 90002S10000 NUT, FLANGE, 10MM £0.17 26 90121SM4010 BOLT, SHOCK ABSORBER FORK (12X98) £5.51 27 90173S84A00 BOLT, RR. UPPER ARM £5.83 28 90181S84A00 BOLT, TRAILING ARM, 12X68 £5.83 29 90215SB0003 NUT, SELF-LOCK, 12MM (SATO RASHI) £3.56 30 90216SE0010 NUT, RR. LOWER ARM, 10MM £4.96 31 90306SB2013 NUT, SELF-LOCK, 10MM £0.1732 90363SF1000 NUT, CASTLE, 12MM £4.00 33 934011002008 BOLT-WASHER, 10X20 £1.28 34 934020801608 BOLT-WASHER, 8X16 £1.15 35 934030601208 BOLT-WASHER, 6X12 £1.00 36 90701SX0003 CLIP, UPPER ARM £3.43 37 957010601608 BOLT, FLANGE, 6X16 £0.86 Should you have any questions feel free to ask us, also there are several alternatives available or upgraded parts at a fraction of the cost of Honda UK prices. e.g shock absorbers, stabilizer links, ball joints ect.Alternatively why not post a wanted advert in the classified section for a NEW or USED part: http://honda6.ipbhost.com/index.php?/forum/89-wanted/ 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 25, 2020 Author Administrators Report Share Posted June 25, 2020 On 9/1/2015 at 9:17 PM, hughezee said: 20 52390S84A01 ARM COMP., RR. UPPER £211.33 Should anybody require and good quality aftermarket part regards the illustrated item 20, I would highly recommend 42172 FEBI BILSTEIN or ADH28654 BLUE PRINT, in fact, they're both identical parts but can vary in price strangely? 5 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 12, 2022 Moderators Report Share Posted March 12, 2022 Just trying to decide what to replace the offside rear shock, that is weeping, with. It's just standard suspension, not lowered, (can't justify cost change 🙃) so I found some called Ridex, anyone tried them? They are cheap though but I need to replace both rear or alternatively an original Honda second hand shock would be acceptable, none leaking of course !!! 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted March 12, 2022 Report Share Posted March 12, 2022 Picture n°4 part n° 10, i bought 2 shock absorber mountings and one came from usa with no rubber ring on top and one came from japan with a rubber ring. Note that from the package i got the one from usa seems from a older stock while the one from japan looked being made more recently. Both parts came with the number 52675S84A01. So what is the purpose of this rubber ring on top of the mounting and why should it be better to use one rather the other ? Seems like a sort of upgrade that has been introduced at some point and wondering which version our coupe got, both ? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 19, 2022 Author Administrators Report Share Posted March 19, 2022 On 3/12/2022 at 9:06 AM, KingK0ng said: Picture n°4 part n° 10, i bought 2 shock absorber mountings and one came from usa with no rubber ring on top and one came from japan with a rubber ring. Note that from the package i got the one from usa seems from a older stock while the one from japan looked being made more recently. Both parts came with the number 52675S84A01. So what is the purpose of this rubber ring on top of the mounting and why should it be better to use one rather the other ? Seems like a sort of upgrade that has been introduced at some point and wondering which version our coupe got, both ? I had this niggle with some KYB parts its no biggy, did you ever order another one for a matching pair, topic linked below? 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted March 19, 2022 Report Share Posted March 19, 2022 50 minutes ago, hughezee said: I had this niggle with some KYB parts its no biggy, did you ever order another one for a matching pair, topic linked below? Wow completely forgot i made a post about this ! I'm going to make an order at some point from Japan for some other parts i need and order another shock mount plate to get those matched. 2 Link to comment Share on other sites More sharing options...
