Administrators hughezee Posted February 6, 2015 Administrators Report Share Posted February 6, 2015 1998-2002 Accord Coupe Alternator Tensioner Inspection & Replacement (3.0L) 1 . Check the position of the auto-tensioner indicator's pointer "A", start the engine and check the position of the pointer again. If the position changes, go to step 5 2 . Check for abnormal noise from the tensioner pulley. If you hear abnormal noise, replace the tensioner pulley. 3 . Stop the engine. Remove the alternator belt. Belt tension release tool e.g Snap-on YA9317 or equivalent. 4 . Check if the auto-tensioner "A" moves smoothly and check for abnormal noise when the pulley is turned counter-clockwise. If the auto-tensioner does not move smoothly or if the there is abnormal noise, replace the auto-tensioner. Do not move the auto-tensioner beyond its limit. 5 . Stop the engine, then remove the auto-tensioner. 6 . Clamp the auto-tensioner "A" by using two 6 mm bolts "B" and a vise "C". Do not clamp the auto-tensioner itself. 7 . Attach a torque wrench to the pulley bolt. Measure the torque when the tensioner is turned counter-clockwise. If the torque is less than the 17 ft.lbs (23 N.m), replace the auto-tensioner. 8 . If necessary, remove the pulley bolt "A" (left-hand threads), and replace the tensioner pulley "B". See Fig. 25 . Hopes this helps somebody, any questions just ask Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted March 29, 2015 Founding Member Report Share Posted March 29, 2015 Blimey, looks complicated? 1 Link to comment Share on other sites More sharing options...
kag8 Posted October 21, 2017 Report Share Posted October 21, 2017 Please could I have the part number for the auto tensioner assembly? Do Gates make a package including the belt. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 21, 2017 Author Administrators Report Share Posted October 21, 2017 Not aware of any package from Gates which includes the Gates K060461 Serpentine Belt and 38169 tensioner, CONTITECH does offer one though ADK0045P or the DAYCO 5060463K1 and for more info on the tensioner check out the post linked below. 1 Link to comment Share on other sites More sharing options...
