Administrators hughezee Posted March 8, 2015 Administrators Report Share Posted March 8, 2015 Topic of a recent telephone conversation with Retro Rich and whilst doing a far amount of suspension work lately I just starting wondering what your thoughts on castle nuts vs. nylon nuts? Personally if the old castle nut looks ok I will re-use and replace the split pin and only use nylon nut where applicable i.e. if it comes with a new suspension component. Although a few people insisted I replace all nuts with nylon nuts when working on their car and never had any issues with them, so I always oblige So what do you reckon Castle nuts or nylon nuts? Link to comment Share on other sites More sharing options...
Founding Member Retro Rich Posted March 24, 2015 Founding Member Report Share Posted March 24, 2015 I used nylon nuts on the Acclaim lower arm. I like the fact that nylon nuts help to keep the threads clear of debris and moisture, whereas castle nuts seem a clever device for collecting debris and salt and accelerating the corrosion process. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 9, 2015 Author Administrators Report Share Posted December 9, 2015 Barley managed to get several nuts an bolts off a members Coupe recently, see one corroded example below Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 9, 2015 Moderators Report Share Posted December 9, 2015 I'm quite fond of Aerotite nuts and failing that, Nyloc nylon-insert locknuts. Definitely don't like castle nuts and split pins - the split pins never seem to want to play first or last and as Rich points out above, they are a trap for salt, mud, dirt, corrosion etc. Also the practice of lining the slot in your nuts up for the split pin - tighten or loosen to line up?? All depends on the application, no hard and fast rule but it can make a difference on a lot of things. So my first preference is Aerotites (preferably in stainless to minimise corrosion) and when they aren't available or practical, Nylocs. 1 Link to comment Share on other sites More sharing options...
