Administrators hughezee Posted September 4, 2014 Administrators Report Share Posted September 4, 2014 Well, I hadn't rehearsed this job, in fact, its my first Honda shuttle timing belt replacement The experience with 5-6th Gen accords stood me in good stead thankfully. Although the limited access wasn't helping matters, nevertheless the 14-year-old belt hung on The belt was starting to get play between the teeth and a distinctive growl now then indicated the timing was shifting a little at 3500-4000 rpm so I'm glad I tackled this job sooner rather than later Anyway, the job is done and she's purring like a kitten, also I opted for the SKF 2 belt kit including, tensioners, oil seals So I wouldn't recommend anybody leave theirs that long no matter how few miles you have any belt older than 6-7 years should be replaced 1 Link to comment Share on other sites More sharing options...
welland99 Posted September 9, 2018 Report Share Posted September 9, 2018 Hi Stu, Have you changed a timing belt on an f20b5? I must check how old mine is.....? 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 10, 2018 Author Administrators Report Share Posted September 10, 2018 8 hours ago, welland99 said: Have you changed a timing belt on an f20b5 yes, it's basically the same belt for all F series with slight variations in aftermarket kits, some make whirring noises as a result, your probably long overdue and a replacement water pump is highly recommended too... 3 Link to comment Share on other sites More sharing options...
welland99 Posted September 19, 2018 Report Share Posted September 19, 2018 On 9/10/2018 at 9:55 AM, hughezee said: yes, it's basically the same belt for all F series with slight variations in aftermarket kits, some make whirring noises as a result, your probably long overdue and a replacement water pump is highly recommended too... Is it a difficult job, or is it feasible for an enthusiastic amateur to have a go in the driveway? Although mine has 186k miles on the clock, I did get the belt changed some years ago, maybe around 140k? So, it might not be well overdue, but perhaps only due. ? Do I take it that if the belt breaks, there is going to be interference between the valves and pistons? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 20, 2018 Author Administrators Report Share Posted September 20, 2018 Yes, the F-series in an interference engine but as you say likely not urgent and should be okay for a couple more years, but the water pump concerns me with that mileage as its driven by the timing belt unless that was replaced last time? Also, I wouldn't say its an easy DIY job either seen plenty of garages and dealers mess up the job using the right tools, I wouldn't recommend it if you've not done one before? 2 Link to comment Share on other sites More sharing options...
