Administrators hughezee Posted October 11, 2020 Administrators Report Share Posted October 11, 2020 This is a common question with the problems that can arise as a result of using the incorrect manual transmission fluid and the problems I have seen when the Honda MTF-3 p/n: 0826799902HE transmission fluid has been used in older transmissions when 10W40 or MTF-2 has been specified for the vehicle. So I have illustrated two of the most common fluids used by myself as a Honda Specialist, so if you are looking for a standard fluid I would recommend any semi-synthetic or fully synthetic 75W-90 Honda or GL-4 compliant fluid (always check the label). For owners looking for the ultimate protection and restored smooth-shifting, I would strongly recommend the Castrol Transmax Manual Multivehicle 75W-90 or COMMA MVMTF Plus 75W-80.👍 However, if your vehicle was factory filled with different weight oil, please replace like for like e.g 10W30 mineral or 10w40 semi-synthetic please message me your registration or VIN number and I can check. PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. Link to comment Share on other sites More sharing options...
