Which Engine Oil for 1996-2001 Honda Prelude 2.0 2.2 "Incl H22"
hughezee
  • Administrators
This is a common question with the problems that can arise as a result of using the incorrect engine oil and problems I have seen when the Honda 0W20 p/n: 08232P99K4LHE engine oil has been used in older engines, which results in oil leaks, high oil consumption and excessive valve train wear and engine noise.
 So I have illustrated a few of the most common oils used by myself or recommended by other members, so if you are looking for just a standard oil I would recommend Shell Helix HX7 AF 5w-30 Engine Oil or Fuchs Titan Race Pro S 5W-30 Engine Oil. Owners looking for good fuel economy and good performance I would highly recommend Mobil 1 ESP Engine Oil 5W-30.
  • Like 2
Link to comment
  • 4 months later...
  • Founding Member
Over the last 6 years I have tried a few types of engine oil and am now sticking to Mobil 1 5w-30.
Iv used Ester based oil from Fuchs Titan pro and was very good indeed.
Also tried Honda 0w-20 oil for the new tyre R and was not inpressed at all.
The oil was to thin in my opinion and reverted back to 5w-30.
Link to comment
  • Founding Member
Yep, I think I will try 5W40 that you recommended Stu as the car is getting older, especially looking at the link you sent about the oil pressure with 0w-20 oil is quite alarming.
Thanks for the quick call.👍
Link to comment
  • 4 weeks later...
