Administrators hughezee Posted April 15, 2021 Administrators Report Share Posted April 15, 2021 This is a common question with the problems that can arise as a result of using the incorrect automatic transmission fluid and the problems I have seen when the Honda ATF-DW1 p/n: 0826899901HE transmission fluid has been used in older transmissions. For more info' please follow this link: https://honda6.ipbhost.com/topic/4790-honda-atf-dw1-warning-warning-warning/ So I have illustrated two of the most common fluids used by myself as a Honda Specialist, so if you are looking for a standard fluid I would recommend Castrol multi-vehicle or Carlube ATF-U both AFT-Z1 compliant (always check the label). For owners looking for the ultimate protection and restored smooth-shifting, I would strongly recommend the AMSOIL signature series.👍 PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. 2 1 Link to comment Share on other sites More sharing options...
