MikeJM Posted April 21, 2021 Report Share Posted April 21, 2021 Hi, I've gone to change the bulb on the passenger side indicator and the grey cli that goes into the indicator bulb holder has come off. Any links fo buy the new loom. I'd add a IC if I could but not sure how. Cheers guys 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 23, 2021 Administrators Report Share Posted April 23, 2021 Sorry to hear of your recent issue, its probably better if you try and reconnect the original fitting as I doubt you can buy a separate section of wiring looming, most Japanese manufacturers make the entire loom to suit the spec of the car, so a whole engine bay wiring loom would be the only solution. But like I said it should easily be fixable, you can buy the universal end fittings with wire tails from eBay, but I would try reattaching the original bulb holder first. 🖐️ 1 Link to comment Share on other sites More sharing options...
