UrbexRobby Posted July 9, 2017 Report Share Posted July 9, 2017 Yes you read this right I WANT THE AIR CON OUT AND REMOVED AND DELETED AND THROWN AWAY LOL Any ideas Link to comment Share on other sites More sharing options...
Administrators hughezee Posted July 9, 2017 Administrators Report Share Posted July 9, 2017 Each to their own Robby Right first off whether your A.C works or not, I would suggest nipping down to a garage with a recovery machine to vacuum the system out to make it safe to work on, simply releasing the refrigerant gas can be very dangerous to your health and is in fact illegal. So once the system is recovered, you will need to release the serpentine belt (moving the tensioner) and then remove the alternator (battery disconnected obviously) don't rush this process, alternators for the Accord V6 aren't cheap to replace. Now remove the two pipes attached the compressor and then remove the compressor itself. Remember to secure the hoses and clutch switch wire with plastic ties to keep them away from moving parts and then fit the Gates K060427 serpentine belt which will work for the none A.C setup. Hope that helps m8y 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 29, 2022 Administrators Report Share Posted September 29, 2022 If anyone wanted to bypass the A.C on a V6 Accord 🥵 you can use a DAYCO 6PK1070 or any 6PK1070-75 serpentine belt. Also available at you nearest Eurotrash parts using product code: 202440995 1 Link to comment Share on other sites More sharing options...
