dbelch Posted September 3, 2016 Report Share Posted September 3, 2016 All of a sudden my brake lights have stopped working. I have tried the obvious bulbs and fuse to no avail. Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 3, 2016 Administrators Report Share Posted September 3, 2016 Since you've done the basics I would check your brake pedal switch p/n: 36750SEA003 2 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted September 3, 2016 Founding Member Report Share Posted September 3, 2016 +1 for break pedal switch. You might be able to bypass the switch to check for sure if not maybe a bad earth. 2 Link to comment Share on other sites More sharing options...
dbelch Posted September 6, 2016 Author Report Share Posted September 6, 2016 Switch ordered being fitted on Wednesday. Hopefully solves the problem . I will post post back . Thanks for the advice. 1 Link to comment Share on other sites More sharing options...
dbelch Posted September 7, 2016 Author Report Share Posted September 7, 2016 Switch fitted everything good . Thanks again for the advice. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 7, 2016 Administrators Report Share Posted September 7, 2016 30 minutes ago, dbelch said: Switch fitted everything good . Thanks again for the advice. Excellent excellent and thank-you for the follow up response Link to comment Share on other sites More sharing options...
