Administrators hughezee Posted December 24, 2015 Administrators Report Share Posted December 24, 2015 Please Note: These images and part numbers relate to the 2000-02 Accord Coupe 3.0 V6 Air Conditioning System only, and has different parts to earlier models. Should your vehicle be a 1998-1999 model please ask us for your vehicles specific part number if your looking to replace a part or repair your air conditioning system Air Conditioning System incl. Hoses & Pipes illustrated with Honda UK Part Numbers.1 80050SP0000 LABEL, AIR CONDITIONER CAUTION (HFC134A) £4.072 80311S87E01 HOSE COMP., SUCTION £118.763 80315S87A01 HOSE COMP., DISCHARGE £131.684 80321S87E01 PIPE COMP., SUCTION £173.275 80331S84E01 PIPE, CONDENSER £104.516 80341S87E01 PIPE COMP., RECEIVER £138.617 80351S84E01 RECEIVER COMP. £150.628 80352S84A00 BRACKET, LIQUID TANK £23.299 80363S84A00 STAY, SUCTION HOSE £13.1910 80365S84A00 CLAMP, SUCTION PIPE £7.1811 80381SV7A01 CLAMP, RECEIVER PIPE £9.3312 80440SS0901 SWITCH, DUAL PRESSURE (FUJI) £54.1913 80865S84003 CAP H, VALVE £7.5614 80866ST7A11 CAP L, VALVE (FAYETTE) £2.6115 80871ST7000 O-RING (5/8") £4.3716 80872ST7000 O-RING (1/2") £4.0917 80873ST7000 O-RING, 8MM £4.8218 91553SM4003 CLAMP, HEATER HOSE (24MM & 39MM) £7.1819 91556S84A01 CLAMP, SUCTION PIPE £4.4620 934030502504 BOLT-WASHER, 5X25 £1.9321 934030601608 BOLT-WASHER, 6X16 £1.9922 9405006080 NUT, FLANGE, 6MM £2.0223 957010602508 BOLT, FLANGE, 6X25 £1.9924 957010603008 BOLT, FLANGE, 6X30 £1.93 Air Conditioning Cooler Unit incl. Expansion Valve illustrated with Honda UK Part Numbers.1 32151S84E00 BRACKET, COUPLER £7.872 39794S0KA01 RELAY ASSY., POWER (4P) (MICRO ISO) (OMRON) £42.832 39794S0KA01 RELAY ASSY., POWER (4P) (MICRO ISO) (TYCO) £42.834 80201S84E00 CASE, EVAPORATOR UPPER £92.065 80202S84E00 CASE, EVAPORATOR LOWER £92.066 80203S84A00 LID, EVAPORATOR UPPER CASE £37.237 80204S84A00 HOLDER, EVAPORATOR £8.828 80205S84E00 INSULATOR, EVAPORATOR UPPER £32.089 80206S84E00 INSULATOR, EVAPORATOR LOWER £32.0810 80207S84A00 INSULATOR £10.1511 80214SL5A01 INSULATOR, EXPANSION £10.5312 80215S84E01 EVAPORATOR COMP. £832.0013 80216S84A01 PIPE, LIQUID £33.1714 80220S84A02 VALVE ASSY., EXPANSION (10N) (FUJI KOKI AMERICA) £209.6615 80223ST7A01 O-RING (FUJI KOKI AMERICA) £3.6016 80225SR3010 CLAMP £5.0817 80286S84A00 SEAL, EVAPORATOR INNER £10.9718 80287S84A00 SEAL, EVAPORATOR OUTER £12.5819 80288S84A00 SEAL, EVAPORATOR PIPE £14.3320 80289S84A00 SEAL, DRAIN £4.8621 80291S84A01 ELEMENT, FILTER £21.6822 80292S84A01 FRAME, FILTER £68.2823 80560SV4A41 SENSOR, EVAPORATOR £33.4524 80566SR3003 CLIP, EVAPORATOR SENSOR £2.5425 80872ST7000 O-RING (1/2") £4.0926 80873ST7000 O-RING, 8MM £4.8227 90155SE0003 SCREW, TAPPING, 6X20 £3.9128 90321SV4003 NUT-WASHER, 6MM (PAINT CUTTING) £5.4229 91556SP0003 CLIP, COUPLER (BROWN) £3.4030 934050602508 BOLT-WASHER, 6X25 £1.9231 9391314280 SCREW, TAPPING, 4X12 (PO) £1.3432 9391314420 SCREW, TAPPING, 4X16 (PO) £1.34 Air Conditioner Condenser incl. Fan illustrated with Honda UK Part Numbers.1 30701883000 CLIP, WIRE HARNESS £2.952 38611P8CA01 FAN COMP., COOLING (MITSUBA) £61.803 38615P8CA00 SHROUD COMP., AIR CONDITIONER £87.344 38616P8CA01 MOTOR, COOLING FAN (MITSUBA) £295.515 80100S87A00 CONDENSER ASSY. (CALSONIC) £455.566 80107S87A01 RUBBER, CONDENSER UPPER £5.447 80111S84A00 BRACKET, CONDENSER MOUNT UPPER £10.088 80175S87A01 RUBBER, CONDENSER MOUNTING £5.449 90012PC6000 BOLT, SPECIAL, 6X12 (+) (DACRO COATING) £3.6710 90041PAAA01 NUT, TOOTHED, 5MM £5.2211 90430P8CA01 WASHER, PLAIN, 8MM £2.8112 934030601604 BOLT-WASHER, 6X16 £1.9913 938930400808 SCREW-WASHER, 4X8 £1.73 Air Conditioner Compressor incl. Drive Belt illustrated with Honda UK Part Numbers.1 38801P9KE01 VALVE SUB ASSY., SAFETY £51.272 38810P8AA01 COMPRESSOR COMP. (DENSO) £1,157.143 38812PH1003 RING B, SNAP £7.274 38812671003 RING A, SNAP £6.375 38816P8AA01 CLIP, LEAD WIRE £4.076 38827PH7003 SCREW-WASHER, 5X8 £3.117 38829PR3003 BOLT, WASHER HEAD £3.878 38838P8CA01 VALVE, SUCTION SERVICE £195.349 38839PR7A01 O-RING £7.8010 38840PC1003 BOLT B £8.2411 38900P8AA01 CLUTCH SET £418.2812 38912PH1N01 PLATE SET, WASHER £7.2113 38920P8CA02 BELT, COMPRESSOR (BANDO) £50.5014 38924P8CA01 STATOR SET £187.5015 38930P8AA00 BRACKET, COMPRESSOR £174.8316 90023P8AA00 BOLT, FLANGE, 8X85 £6.4817 957011005008 BOLT, FLANGE, 10X50 £2.18 A.C System Internal & External Temperature Sensors illustrated with Honda UK Part Numbers.1 80510S84A41 SENSOR ASSY., SUN BEAM £67.252 80521SS0940 BRACKET, AMBIENT SENSOR £8.883 80525SS0942 SENSOR, AMBIENT £52.944 80530S84E41ZC SENSOR ASSY., IN CAR *YR169L* £48.944 80530S84E41ZD SENSOR ASSY., IN CAR *NH264L* £48.945 80533S84A40 HOSE, ASPIRATOR £12.926 90666SD4003 CLIP, FITTING £3.227 934030601604 BOLT-WASHER, 6X16 £1.99 You maybe horrified by some of the prices of some replacement parts e.g compressor or condenser No need to worry as you can typically replace your accords condenser for less than £75 and you can find used compressors from £65 or alternatively a band new one for £250 (I wouldn't recommend a manufactured unit) So if you have a parts question don't hesitate to ask us Link to comment Share on other sites More sharing options...
