Administrators hughezee Posted September 5, 2014 Administrators Report Share Posted September 5, 2014 Front Shock Absorber illustrated with Honda UK Part Numbers.1 51401S84A12 SPRING, FR. (SHOWA) £96.07 2 51601S82A17 ABSORBER ASSY., R. FR. SHOCK (###) £305.21 3 51602S82A17 ABSORBER ASSY., L. FR. SHOCK (###) £305.22 4 51605S82A05 ABSORBER UNIT, R. FR. SHOCK £180.47 5 51621S84A01 WASHER, SHOCK ABSORBER MOUNTING £3.30 6 51631SV7004 RUBBER, SHOCK ABSORBER MOUNTING (SHOWA) £12.50 7 51675S84A01 BASE, FR. SHOCK ABSORBER MOUNTING (SHOWA) £57.12 8 51685SR0004 PLATE, DUST COVER (A.S.I. SHOWA) £3.46 8 51685SH3014 PLATE, DUST COVER (SHOWA) £4.91 9 51686S84A01 RUBBER, FR. SPRING MOUNTING £23.23 10 51689SH3004 PLATE, BUMP STOP (SHOWA) £5.95 11 51689SP0004 COVER, DUST (SHOWA) £9.37 12 51722S84A01 RUBBER, FR. BUMP STOPPER (A.S.I. SHOWA) £20.35 13 51728SB0004 COLLAR, SHOCK ABSORBER MOUNTING (SHOWA) £5.35 13 51728SR0003 COLLAR, SHOCK ABSORBER MOUNTING (DUFFY STEEL PARTS) £1.58 14 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM) £3.91 15 90364SG0004 NUT, SELF-LOCK, 10MM (SHOWA) £3.60 16 51606S82A03 ABSORBER UNIT, L. FR. SHOCK £180.47 Front Suspension (incl. ABS) Upper Arm & Knuckle illustrated with Honda UK Part Numbers.1 51210S84A02 KNUCKLE COMP., R. FR. £372.492 51215S84A02 KNUCKLE COMP., L. FR. £372.49 3 51225S84A01 BOOT, LOWER BALL DUST £10.84 4 51450S84A01 ARM COMP., R. FR. UPPER £275.765 51460S84A01 ARM COMP., L. FR. UPPER £275.766 51464S04013 BOOT, UPPER BALL JOINT £20.12 7 52226SL0003 CIRCLIP, LOWER BALL (MUSASHI) £7.26 8 52338SL0003 CIRCLIP, CONTROL ARM £4.56 9 57450S84A52 SENSOR ASSY., R. FR. £208.49 11 57451S82G01 BRACKET, SECURITY HORN £6.98 12 57451S84A50 BRACKET, L. COUPLER £5.15 14 57455S84A52 SENSOR ASSY., L. FR. £208.49 15 90172S04003 BOLT, FLANGE, 10X68 £3.80 16 90321SE0000 NUT, UPPER BALL PIN, 10MM £4.18 17 90363SZ3003 NUT, UPPER ARM, 12MM £5.40 18 91540SV4003 CLIP, HARNESS BAND (NATURAL) (145.2MM) £3.77 19 934020601208 BOLT-WASHER, 6X12 £0.86 20 9407006080 NUT-WASHER, 6MM £0.86 21 9420120180 PIN, SPLIT, 2.0X18 £0.59 22 9420130220 PIN, SPLIT, 3.0X22 £0.71 24 957010601208 BOLT, FLANGE, 6X12 £0.86 25 957010601608 BOLT, FLANGE, 6X16 £0.86 Front Suspension Lower Arm & Stabilizer illustrated with Honda UK Part Numbers.1 51300S84A01 SPRING, FR. STABILIZER £199.28 2 51306S84A01 BUSH, STABILIZER HOLDER £8.93 3 51308SW3000 BRACKET, FR. STABILIZER £10.32 4 51320S84A01 LINK COMP., R. FR. STABILIZER £56.21 5 51321S84A01 LINK COMP., L. FR. STABILIZER £56.21 6 51352S84A01 ROD, R. FR. RADIUS £108.98 7 51355S84A00 ARM COMP., R. FR. LOWER £274.85 8 51362S84A01 ROD, FR. RADIUS £97.38 9 51365S84A00 ARM COMP., L. FR. LOWER £190.16 10 51381S84A01 BUSH, FR. RADIUS ROD (RR.) £13.61 11 51391S84A01 BUSH, RADIUS ROD (FR.) £13.61 12 51393SV1A01 BUSH, FR. LOWER ARM £27.59 13 51394S84000 WASHER, CASTER ADJUSTER £3.16 14 51398SM4000 COLLAR, RADIUS ROD £7.91 15 51399S0A000 WASHER, FR. RADIUS ROD £5.96 16 51810SV4004 BUSH, SHOCK ABSORBER FORK (YAMASHITA) £30.19 16 51810SV4003 BUSH, SHOCK ABSORBER FORK (HOKUSHIN) £30.19 17 51811S84A00 FORK, R. FR. SHOCK ABSORBER £115.48 18 51821S84A00 FORK, L. FR. SHOCK ABSORBER £123.20 19 74180S84E00 BAR COMP., R. FR. STRUT £75.94 20 74185S84E00 BAR COMP., L. FR. STRUT £75.94 Rear Shock Absorber illustrated with Honda UK Part Numbers.1 51621S84A01 WASHER, SHOCK ABSORBER MOUNTING £3.30 2 51685SH3014 PLATE, DUST COVER (SHOWA) £4.91 2 51685SR0004 PLATE, DUST COVER (A.S.I. SHOWA) £3.46 3 51728SB0004 COLLAR, SHOCK ABSORBER MOUNTING (SHOWA) £5.35 3 51728SR0003 COLLAR, SHOCK ABSORBER MOUNTING (DUFFY STEEL PARTS) £1.584 52441S84A02 SPRING, RR. (SHOWA) £90.045 52610S82A02 ABSORBER ASSY., R. RR. SHOCK (###) £267.676 52611S82A02 ABSORBER UNIT, RR. SHOCK £158.127 52620S82A02 ABSORBER ASSY., L. RR. SHOCK (###) £254.93 8 52622S84A01 BUSH, RR. SHOCK ABSORBER LOWER £20.86 9 52631S84A01 RUBBER, RR. SHOCK ABSORBER MOUNTING (SHOWA) £12.73 (10 52675S84A01 BASE, RR. SHOCK ABSORBER MOUNTING (A.S.I. SHOWA) £66.95 11 52686S84A01 RUBBER, RR. SPRING MOUNTING £25.52 12 52688S84A02 SLEEVE, RR. DUST COVER £37.3913 52690SG0000 PLATE, BUMP STOP £6.6414 52722SV1A02 RUBBER, RR. BUMP STOPPER (SHOWA) £23.4514 52722SM4013 RUBBER, BUMPER STOPPER (POLYURETHAN KASEI) £23.4515 52748S84A02 COVER, RR. LOWER MOUNT DUST £15.32 16 90182S84A00 BOLT, RR. DAMPER, (10X81) £5.8317 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM) £3.9118 90364SG0004 NUT, SELF-LOCK, 10MM (SHOWA) £3.60 19 52689SG0014 END, DUST COVER £11.41 Rear Suspension Lower Arm & Stabilizer illustrated with Honda UK Part Numbers.1 52210S84A52 KNUCKLE COMP., R. RR. £552.18 2 52215S84A52 KNUCKLE COMP., L. RR. £350.463 52300S82A01 SPRING, RR. STABILIZER £156.01 4 52306S82A01 BUSH, RR. STABILIZER HOLDER £23.12 5 52308SZ5000 HOLDER, STABILIZER BUSH £9.89 6 52320S84A01 LINK COMP., R. RR. STABILIZER £54.617 52325S84A01 LINK COMP., L. RR. STABILIZER £54.618 52338SL0003 CIRCLIP, CONTROL ARM £4.56 9 52340S84A01 BRACKET, R. RR. LINK STABILIZER £15.95 10 52345S84A01 BRACKET, L. RR. LINK STABILIZER £15.9511 52350S84A01 ARM COMP., RR. LOWER £81.80 12 52360S84A01 ARM COMP., RR. CONTROL £92.60 13 52364634020 WASHER, LOWER ARM £2.82 14 52365SM4004 BUSH A, RR. LOWER ARM (YAMASHITA) £14.78 15 52370S84A51 ARM COMP., R. RR. TRAILING (DISK) £46.42 16 52375S84A51 ARM COMP., L. RR. TRAILING (DISK) £143.2417 52380S84A01 ARM COMP., RR. LEADING £49.67 18 52387S84A00 BOLT, CONTROL ADJUSTING £11.57 19 52388S84A00 PLATE, CAM £4.49 20 52390S84A01 ARM COMP., RR. UPPER £211.33 21 52454S84A01 BOOT, UPPER DUST £14.8422 57452S84A50 BRACKET, RR. COUPLER £3.46 23 57470S0KA53 SENSOR ASSY., R. RR. £220.10 24 57475S0KA53 SENSOR ASSY., L. RR. £220.14 25 90002S10000 NUT, FLANGE, 10MM £0.1726 90121SM4010 BOLT, SHOCK ABSORBER FORK (12X98) £5.5127 90173S84A00 BOLT, RR. UPPER ARM £5.83 (€6.65) ($9.68)28 90181S84A00 BOLT, TRAILING ARM, 12X68 £5.83 29 90215SB0003 NUT, SELF-LOCK, 12MM (SATO RASHI) £3.56 30 90216SE0010 NUT, RR. LOWER ARM, 10MM £4.96 31 90306SB2013 NUT, SELF-LOCK, 10MM £0.17 32 90363SF1000 NUT, CASTLE, 12MM £4.00 33 934011002008 BOLT-WASHER, 10X20 £1.28 34 934020801608 BOLT-WASHER, 8X16 £1.15 35 934030601208 BOLT-WASHER, 6X12 £1.00 36 90701SX0003 CLIP, UPPER ARM £3.4337 957010601608 BOLT, FLANGE, 6X16 £0.86 # Should you have any questions feel free to ask us, also there are several alternatives available or upgraded parts at a fraction of the cost of Honda UK prices. e.g shock absorbers, stabilizer links, ball joints ect.Alternatively why not post a wanted advert in the classified section for a NEW or USED part: http://honda6.ipbhost.com/index.php?/forum/89-wanted/ Link to comment Share on other sites More sharing options...
