Administrators hughezee Posted June 15, 2015 Administrators Report Share Posted June 15, 2015 Selection of service items for you 1998-2002 Honda Accord Coupe 2.0 or 2.3, Honda UK Part numbers & Prices Element Air Filter: 17220PAAA00 ELEMENT ASSY., AIR CLEANER £27.60 Pollen Cabin Filter: 80291S84A01 ELEMENT, FILTER £21.47 Two required In-line Fuel Filter 16900S84G01 STRAINER COMP., FUEL £38.84 Engine Oil filter: 15400RBAF01 CARTRIDGE, OIL FILTER (LABINAL-PURFLUX) £13.28 Oil Sump Bolt Washer: 9410914000 WASHER, DRAIN PLUG, 14MM £0.71 ATF Drain Bolt Washer: 90441PK4000 WASHER, SEALING, 24MM £3.79 Engine Spark Plugs: 980795514G PLUG, SPARK (ZFR5F-11) (NGK) £7.00 Four required Engine Spark Plugs: 980795515G PLUG, SPARK (KJ16CR-L11) (DENSO) £7.00 Four required Engine Spark Plugs: 980795614G PLUG, SPARK (ZFR6F-11) (NGK) £7.00 Four required Engine Spark Plugs: 980795714G PLUG, SPARK (ZFR7F-11) (NGK) £7.00 Four required Engine Spark Plugs: 980795715G PLUG, SPARK (KJ22CR-L11) (DENSO) £7.00 Four required Should you have any questions feel free to ask us, also there are OEM or aftermarket alternatives available at a fraction of the cost of Honda UK prices. e.g oil, air, fuel, pollen filters ect. Link to comment Share on other sites More sharing options...
