Administrators hughezee Posted December 11, 2015 Administrators Report Share Posted December 11, 2015 Front Brakes and Bearing + Hub illustrated with Honda UK Part Numbers.1 01463SP0E00 CALIPER SET, FR. £87.112 43352SM4951 SCREW, BLEEDER £6.12 3 43353SD5003 CAP, BLEEDER SCREW £3.55 4 44300S84A01 BEARING ASSY., FR. HUB (NTN) £107.32 6 44600S87A00 HUB ASSY., FR. £180.92 7 45018S87G02 CALIPER SUB ASSY., R. FR. £360.00 8 45019S87G02 CALIPER SUB ASSY., L. FR. £360.00 9 45022SL0E61 PAD SET, FR. (16CL-15VN,NS146H) £61.3210 45213SP0E01 PISTON (42MM) £67.91 13 45227SL0013 SPRING, PAD £25.10 15 45235S0KA01 PIN A £16.26 16 45237SL0003 RETAINER £14.69 17 45240SM4003 BOLT, FLANGE, 10X24 £4.09 19 45251S87G00 DISK, FR. BRAKE (15") £74.10 20 45255SS0G00 GUARD, FR. BRAKE SPLASH £57.29 21 45262S0KA01 PIN B £16.26 22 90107SM4000 BOLT, CALIPER MOUNTING (12X21) £3.37 23 90113S84901 BOLT, WHEEL (ROCKNEL FASTENER) £5.00 24 90681SG0000 CIRCLIP, INTERNAL, 84MM £14.20 25 938920601408 SCREW-WASHER, 6X14 £0.86 (26 06450S84E51 PAD SET, FR. (WITHOUT SHIM) (###) £61.32 27 06455S0KJ10 SHIM SET, FR. £38.53 28 93600060140H SCREW, FLAT, 6X14 £2.05 Rear Brakes and Bearing + Hub illustrated with Honda UK Part Numbers.1 01473SY8010 CALIPER SET, RR. £43.57 2 42200S87C51 BEARING ASSY., RR. HUB UNIT £168.64 3 42326ST7Z00 CAP, HUB UNIT £7.45 4 42510S87A00 DISK, RR. BRAKE £66.43 5 43018S84A11 CALIPER SUB ASSY., R. RR. £349.78 6 43019S84A11 CALIPER SUB ASSY., L. RR. £314.06 7 43022SY8E50 PAD SET, RR. (AD34-P,D6234) £51.11 8 43215SY8A01 PISTON ASSY. £46.24 9 43217SY8A01 SLEEVE £33.94 11 43227SY8A01 SPRING, PAD £12.82 12 43228S84A13 LEVER, R. £31.90 13 43229SY8A02 ROD £0.00 14 43233SY8A01 CONNECTOR £22.61 15 43237SY8A01 SPRING A, ADJUSTER £5.57 16 43238SY8A01 RING, RETAINING £7.93 17 43241SY8A01 GUIDE, SPRING £7.93 18 43244SY8A01 RETAINER £9.83 19 43246S84A12 SPRING, R. RETURN £9.50 20 43247S84A13 ARM, R. £25.70 21 43248S84A13 LEVER, L. £31.90 22 43253S84A50 GUARD, R. RR. SPLASH £39.29 23 43254S84A50 GUARD, L. RR. SPLASH £41.93 24 43266S84A12 SPRING, L. LEVER RETURN £9.50 25 43267S84A13 ARM, L. £24.10 26 45215671672 SCREW, BLEEDER £11.59 27 45219S84A01 CAP, BLEEDER SCREW £3.59 28 45233S01A01 BUSH £6.13 29 45235S01A01 PIN A £11.95 30 45240S01A01 BOLT £4.32 31 45262S01A01 PIN B £12.14 32 90103SV4003 BOLT, FLANGE, 10X30 £4.9933 90113SM1005 BOLT, WHEEL (ROCKNEL FASTENER) £4.3734 90305S30003 NUT, SPINDLE £8.71 35 934121002508 BOLT-WASHER, 10X25 £1.02 36 93600060140H SCREW, FLAT, 6X14 £2.05 37 957010601208 BOLT, FLANGE, 6X12 £0.86 38 06430S84E50 PAD SET, RR. (WITHOUT SHIM) (###) £51.11 39 06435S84A00 SHIM SET, RR. £9.54 Hand/ Parking Brake illustrated with Honda UK Part Numbers.1 47105S84E02ZA LEVER ASSY., PARKING BRAKE *NH167L 1* £74.18 Coloured Part - dark grey2 47142S84A01 KNOB, PUSH ROD £3.30 3 47143SD4300 SPRING, PUSH ROD £3.14 4 47342SZ3003 SWITCH, PARKING BRAKE £10.27 5 47360SB2000 EQUALIZER £11.71 6 47365538000 PIN, EQUALIZER £3.86 7 47510S82A53 WIRE, R. PARKING BRAKE £104.72 8 47522594000 NUT, PARKING BRAKE ADJUSTING £6.19 9 47537671670 SPRING, PARKING BRAKE ROD £2.42 10 47560S82A52 WIRE, L. PARKING BRAKE £104.72 11 90651SV1A01 CLIP, BRAKE HOSE £4.26 12 934020802008 BOLT-WASHER, 8X20 £1.15 13 934030801608 BOLT-WASHER, 8X16 £1.28 14 938920401208 SCREW-WASHER, 4X12 £0.55 Brakes Lines RH illustrated with Honda UK Part Numbers.1 01464S84A01 HOSE SET, R. FR. BRAKE £73.57 2 01465S84A01 HOSE SET, L. FR. BRAKE £73.57 3 01466S84A51 HOSE SET, R. RR. BRAKE £47.99 4 01468S84A51 HOSE SET, L. RR. BRAKE £47.99 5 46210S10A52 VALVE ASSY., PROPORTIONING £200.24 6 46330S82A00 PIPE COMP. C, BRAKE £164.71 7 46340S82G00 PIPE COMP. D, BRAKE £137.83 8 46374S87E50 PIPE COMP. U, BRAKE £45.17 9 46375S87E50 PIPE COMP. V, BRAKE £45.17 10 46376S87A50 PIPE COMP. W, BRAKE £37.63 11 46377S87E50 PIPE COMP. X, BRAKE £105.43 12 46378S87E50 PIPE COMP. Y, BRAKE £90.35 13 46379S87E50 PIPE COMP. Z, BRAKE £79.08 14 46380SH3000 GROMMET A, BRAKE PIPE £3.85 15 46393SM4951 CLIP C £2.92 16 46391S84A51 CLIP, BRAKE PIPE £2.65 17 46392S84A50 CLIP, BRAKE PIPE £9.05 18 46391SX8T01 CLIP, BRAKE PIPE £2.65 19 46393S84A00 CLAMP, BRAKE PIPE £7.97 20 46394SH3A01 CLIP, BRAKE PIPE £4.3021 46394S84E50 CLIP, BRAKE PIPE £6.65 22 46435S84A00 BRACKET, RR. BRAKE HOSE £12.04 23 46462SE0000 BOLT, OIL £5.76 24 46472568000 PACKING, OIL BOLT £4.06 25 90651SV1A01 CLIP, BRAKE HOSE £4.26 26 934030601608 BOLT-WASHER, 6X16 £1.00 27 934030801608 BOLT-WASHER, 8X16 £1.28 28 957010601208 BOLT, FLANGE, 6X12 £0.86 29 957010801608 BOLT, FLANGE, 8X16 £1.00 30 958010604508 BOLT, FLANGE, 6X45 £1.28 Brake ABS Modulator/ Pump illustrated with Honda UK Part Numbers.1 57101S30003 RUBBER, ABS MOUNTING £4.46 2 57102S30003 HOLDER, ABS £6.56 3 57110S84A51 MODULATOR ASSY., ABS £1,119.55 4 57115S87A50 BRACKET, MODULATOR £40.40 5 934040601608 BOLT-WASHER, 6X16 £0.86 6 9407106080 NUT-WASHER, 6MM £0.86 Brakes Master Cylinder illustrated with Honda UK Part Numbers.1 46070SL0G01 PLATE, SYMBOL MARK £3.19 2 46100S84E52 CYLINDER ASSY., MASTER £316.18 3 46120S84A51 PISTON ASSY., PRIMARY £56.21 4 46122S84A51 PISTON ASSY., SECONDARY £39.40 5 46151SB2003 YOKE, PUSH ROD (NISSIN) £10.60 6 46182S84A51 CIRCLIP £3.65 7 46185S04J01 SEAL, ROD £6.07 8 46191634000 GASKET, MASTER CYLINDER BRACKET £4.08 9 46400S84E51 POWER ASSY., MASTER (8"+9") £722.24 11 46402S87E01 TUBE ASSY., MASTER POWER £12.62 13 46407S84A01 CLAMP, TUBE £3.94 14 46512S70000 PIN, PEDAL £6.04 15 46660S84E02 RESERVOIR COMP. £37.34 16 46662S04J01 CAP COMP., RESERVE TANK £105.73 17 46665S04J01 GROMMET £12.04 18 46666S04J01 FILTER, BRAKE RESERVOIR £18.67 19 46669692003 SEAL, RESERVE TANK £7.25 20 53729671003 CLAMP D, 15.5MM £4.43 21 57515S30003 PIN, STOP £3.83 22 92301050250H BOLT, RECESSED, 5X25 £0.86 24 94001080800S NUT, HEX., 8MM £1.07 25 9405008080 NUT, FLANGE, 8MM £1.67 26 9407008080 NUT-WASHER, 8MM £0.86 27 9411108800 WASHER, SPRING, 8MM £0.65 28 46911S70003 PIN, LOCK (8MM) £4.44 Should you have any questions feel free to ask us, also there are several alternatives available re-manufactured or upgraded parts at a fraction of the cost of Honda UK prices. e.g calipers, brake hoses, brake rotors, brake pads ect.Alternatively why not post a wanted advert in the classified section for a NEW or USED part: http://honda6.ipbhost.com/index.php?/forum/89-wanted/ Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted December 12, 2015 Founding Member Report Share Posted December 12, 2015 Good stuff. 1 Link to comment Share on other sites More sharing options...
