Moderators PTR200S Posted July 31, 2020 Moderators Report Share Posted July 31, 2020 The Elysion has a power socket in the tailgate area. Rated at 100 volts / 100amps if I recall , Darren has used a converter to get 240v, but just wondered if anyone has converted socket, in any imported vehicle, to UK output without using an external converter? Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted July 31, 2020 Founding Member Report Share Posted July 31, 2020 Wow, that is some current pull from a 12v battery if it gives 100A at 100v. Hope the cables are up to that & do not get too hot! I used a 3KW 240v inverter from a big leisure battery (to power a 2.5kw electric compressor) which rarely gave power for more than 1hr and that had very big cables - like starter leads - directly from the battery to the inverter 1 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 1, 2020 Author Moderators Report Share Posted August 1, 2020 Quite right , Paul !!!!!! Its not 100amps, watts not amps !!!! no idea why I wrote that and didn't think about it!!!! Its actually 100v / 100 w !! Erm, 1amp !!!!!... 1 Link to comment Share on other sites More sharing options...
