This morning the handbrake and 'rear brake lamp' warning lights stayed on, even though the handbrake was off and the brake lamps are all working. When I got to my garage the warnings mysteriously went off and then came on again. Mechanic thinks it might be a failed/failing sensor in the brake fluid reservoir - does this sound likely, and if so, where can I get a new sensor from?
